Route object
May 21st, 2008
Dear all,
Do anybody have an idea of why ISp ask customer to crate Route Object in the registry site.
And if route object is created for /20 pool then Provider asks to create route object for /24 pool which he is going to announce through provider
Please suggest
Mahesh
Overall Rating: 3 (1 ratings)
guruprasadr Thu, 05/22/2008 - 11:20
  • Gold, 750 points or more
HI Mahesh, [Pls RATE if HELPS]
MOST of the Level-1 ISP's will accept the Prefixe's only if the "Route-Object" is created with APNIC.
The APNIC is the General body, authorises the Prefixes to which company they belong / registered to and in addition how it was advertised to the Service Provider and what are the Primary / Secondary / Tertiary provider details.
This Enable's easy database Management across Internet Cloud.
All ISP will accept and also advertise only /24 prefix and not more than that. It's a General Standard followed across the Internet Cloud to avoid the Network Failures. This standard was followed, to avoid the more specific prefixes took over the aggregation routes.
Hope I am Informative.
Pls RATE if HELPS
Best Regards,
Guru Prasad R
