Trace route using an Ip Phone
May 21st, 2008
Hi all,
due to troubleshooting issue over Unity,
we are looking for a way to follow step by step packets route between a test Ip Phone and Unity itself.
So, is there any workaround to perform a sort of tracert command using phone directly ? In this way could be possible to follow packet route from origin to endpoint.
Thanks in advance
Federico
mattcalderon Wed, 05/21/2008 - 04:39
  • Silver, 250 points or more
Not that I have every heard of. I would just trace route from the default-gateway of the phone and source the trace from the same subnet the phone resides in.
Jaime Valencia Wed, 05/21/2008 - 06:01
  • Cisco Employee,
  • Hall of Fame,
    2011
get a sniffer trace. that will show you all the traffic to and from the phone
javalenc
if this helps, please rate
_cisco4ever Fri, 05/23/2008 - 03:39
well, sniffer already used..
but you can see only packet with source and destination addresses related to the end-points and not which are the middle-hop between ip phone and Unity.
This is the reason why we are looking for a way to simulate tracert command.
m_zabetian Mon, 06/02/2008 - 11:22
Get laptop connect to port change port access Vlan to voice Vlan and then try to do the tracert .
