Clean Access Agent Link Distribution
May 21st, 2008
Hi Guys,
I'm installing Clean Access VG OOB. Problem is that I get the user to login via CAA, if they fail the AV check (can have any AV vendor) then they are pushed off to URL to download the corporate AV software. Once the software is installed the CAA doesn't offer the option of clicking the next button it just sits there with the temporary access timer ticking away. If I cancel then re-login the client is then logged in successfully as he has passed posture assessment. I have tried a seperate installation of CAA via msi file but still getting the same problem.
Any ideas?
