05-21-2008 04:50 AM
Hello sir,
We are using Ciscoworks lms 3.0 in our network .
Frequently, we are getting the following error through mail from DFM .
EVENT DESCRIPTION = HighQueueDropRate::Component=IF-ROUTER-1/13 [AT1/0/0];ComponentClass=Interface;ComponentEventCode=1053;Type=SONET;OutputPacketQueueDropPct=1.3081062 %;MaxSpeed=150000000;OutputPacketQueueDropRate=3.3625 PPS;OutputPacketNoErrorR
CUSTOMER IDENTIFICATION =
The polling and threshold setting are default in DFM manager.
Where we can find the parameters for this error.
What changes we have to make in order to avoid this problem.
Your help is highly appreciated,
Ashraf
05-21-2008 05:11 AM
Go to DFM - Configuration - Polling and Thresholds- Managing Thresholds
Select your DFM - System Defined Groups and your specific interface category
Then modify the queue drop threshold
05-24-2008 09:40 PM
Thanks a lot for your clarification. As u mentioned in your reply, i have done the same procedure and changed the queue drop threshold to 4% by default it is 1% still I am getting the same error message.
Note: we are getting these errors at peak hours when the users are not connected in network.
Please give an alternate solution to solve this problem.
OutputPacketQueueDropPct=2.4191074 %;MaxSpeed=150000000;OutputPacketQueueDropRate=1.8791667
kareem
05-27-2008 09:22 PM
please help me for this issue
05-28-2008 01:10 AM
any updates for dfm queuedrop thersold error
06-09-2008 10:39 PM
please help me to avoid these errors.
06-10-2008 09:16 PM
any updates
