AP1121 and Cisco 7920
May 21st, 2008
I've configured AIR-AP1121G-A-K9 and clients already associated adn they works with out problems-
xxx#sh dot11 associations
802.11 Client Stations on Dot11Radio0:
SSID [xxx] :
MAC Address IP address Device Name Parent State
0040.96b1.59a5 CB21AG/PI21AG RG07 self Assoc
0040.96b5.167d CB21AG/PI21AG RG11 self Assoc
0040.96b5.16d3 CB21AG/PI21AG RG15 self Assoc
I'm trying to connect Cisco 7920 phone to AP but failed.
First question - does AP1121 support Cisco 7920?
Overall Rating: 3 (2 ratings)
jeromehenry_2 Wed, 05/21/2008 - 07:42
I am not sure that there would be incompatibility in the hardware, but probably in the authentication process... what kind of settings has the SSID you try to connect your phone to?
A few debug might help also. 7920 has specific requirements to associate (IOS version 12.3(8) or later, QOS enabled, etc)...
migilles Wed, 05/21/2008 - 13:20
Yes 7920 is supported on the AP1121G. What authentication are you trying to use?
If using key-management (WPA, WPA-PSK, CCKM), then would want to set the phone to AKM mode. LEAP and EAP-FAST modes can do WEP w/ optional CCKM.
Would suggest to try a ssid w/ open and no encryption first, then can increase authentication & encryption.
