Cisco 1242 AP configuration - Disable console and 802.1x for the AP
May 21st, 2008
Hi guys,
Many thx thuis far for the excellent help on this forum for the wifi stuff - it is so valued :)
Couple of points I have.
1. Do most people change the console password on their AP from the non default OR is there a way to disable console access on a 1242LWAP ?
2. In release 12.3(8)JA
http://www.cisco.com/en/US/prod/collateral/wireless/ps5678/ps6521/prod_bulletin0900aecd8041ab07.html
IEEE 802.1X Supplicant
This feature supports an 802.1X supplicant for EAP-FAST and EAP-TLS that provides a secure method for enabling 802.1X authentication on the switch ports that are connected to access points.
Does anyone use this feature or just use the SSL/TLS exchange between AP and WLC?
Thx
Ken
jeromehenry_2 Wed, 05/21/2008 - 07:29
  • Silver, 250 points or more
I change the default password, easy to do now on code 5.0 from the controller GUI.
I don't use the supplicant, but AP authorization list on the WLC...
J
Trending Topics - Security & Network
