Application Layer
May 21st, 2008
Dear ALL,
I'd like to know if is there a CISCO firewall able to perform layer application filtering task, like protection from cross site scripting and sql injections.
Alberto Brivio
oszkari Thu, 05/22/2008 - 07:19
You can create regular expressions specific to those attacks and filter using Modular Policy Framework.
One example for xss attacks would be:
regex url "(^)*(http)"
policy-map type inspect http http_in
match request uri regex url
drop-connection log
Hope it was helpful.
suschoud Thu, 05/22/2008 - 12:40
  • Gold, 750 points or more
i think for writing the regular expressions corresponding to an attack would be too much of configuraiton.
I would suggest enabling default signatures on asa using ip audit commands.
that would take care of most frequently seen attacks.
now,to be safe against every new attack which come out,f/w would need an aip-ssm module in it.the intrusion prevention module can defend the network against any known attack.it has a huge database of signatures which get updates regularly on cisco website.
hth,
Sushil
oszkari Thu, 05/22/2008 - 23:20
Sorry but I must disagree:)
You are right, it is a litle bit work doing regexs but, as far as I know the built-in signatures on a cisco firewall (ASA/PIX) does not cover the sql injection and xss related attacks.
Obviously a better solution would be an AIP-SSM, but then we would talk about filtering with an IPS and not a firewall:)
