Firmware update issue
May 21st, 2008
Hello all.
I have been doing upgrades on APs in our network and one of the AP1200 units had firmware 122-11.JA3 loaded. It would not take the http upgrade, so I loaded 123-4.JA2 via tftp. The file actually made it all of the way onto the Ap without stalling, but it did not finish the process of removing the previous firmware and replacing it with the new tar file.
As of right now, here is the result of a show flash:
2 -rwx 4884480 May 21 2008 14:23:41 c1200-k9w7-tar.123-4.JA2.tar
3 -rwx 1939 May 20 2008 11:50:03 private-config
4 -rwx 5480 May 20 2008 11:50:03 config.txt
5 -rwx 2560 May 21 2008 14:26:47 config.txt.new
6 -rwx 95 May 19 2008 16:49:03 env_vars
7 drwx 320 Jan 01 1970 00:06:48 c1200-k9w7-mx.122-11.JA3
Since the 122-11.JA3 file is a directory I cannot delete it, and I am unsure of the commands to overwrite the old firmware with the new.
And yes, after loading this version, which is the oldest usable firmware available, I will upgrade to 123-8.JEC1. This is just a two step process of upgrading the old firmware.
Any help would be greatly appreciated.
thanks
Matt
bcolvin Thu, 05/22/2008 - 19:10
  • Bronze, 100 points or more
Matt
Your prob;em is the current images exceed the 4Mb limit for HTTP transfers, you need to use TFTP to transfer the new image.
The AP has the same problem earlier versions did not support the 4mb+ file sizes.
the process is two step first upgrade to 12.2(13) with TFTP or HTTP this version supports large files( over 4mb) then the use tftp to load the current release
Good luck
Bill
dundeenit Sun, 05/25/2008 - 15:55
As you already have the tar file, and can log in to your AP and copy via a tftp server, i would suggest using the archive command to upgrade you AP via tftp rather than copying it to the AP then upgrading it.
archive download-sw /overwrite tftp://x.x.x.x/c1200-k9w7-tar.123-4.JA2.tar
where x.x.x.x is the IP address of the tftp server
then repeat the command again withthe latest IOS version you want to use.
Hope this helps
George
engineerangelo Mon, 05/26/2008 - 02:09
I have a simple suggestion. Upgrade it using CNA. This is much easier and much simpler. Thanks.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
