IS-IS Level-2 into Level-1
Sergey Zaytsev Thu, 05/22/2008 - 03:47
Hello!
In 12.4T no problem!
Here is example.
Null process is level-1-2, l1-1 process is level-1.
Route-map is blank, so any l2-route is passing.
interface Serial1/0
ip address 10.60.1.1 255.255.255.252
ip router isis
interface Serial1/1
ip address 10.11.0.1 255.255.255.252
ip router isis l1-1
router isis
net 47.0000.1921.6810.0002.00
metric-style wide
log-adjacency-changes
router isis l1-1
net 47.0001.1921.6810.0002.00
is-type level-1
metric-style wide
redistribute isis ip level-2 into level-1 route-map r1
route-map r1 permit 10
But.....I tried the same config on 12.2SRC - not working! :(
Auto l1->l2 redistribution is absent!
LSPs ATT-bit in level-1 is set to zero, so l1-default is absent too!
Like two different domains!?
Tried manual redistribution between processes....no success.
Combined configuration is working fine!
Any ideas?
Hi there,
Thanks for you reply. What i'm trying to achieve is below ;
router isis
metric-style wide
is-type level-1
redistribute isis LEVEL2 ip level-2 into level-1 route-map r1
router isis LEVEL2
is-type level-2
metric-style wide
The probem i'm facing is when i try to enter "redistribute isis LEVEL2 ip level-2 into level-1 route-map r1" under the router isis process, the router fails to accept. I get an error saying
Rack1R1(config-router)#redistribute isis TEST ?
% Unrecognized command
Any clue why this is happening.
Thanks.
Sergey Zaytsev Sun, 05/25/2008 - 20:04
Hi!
Try to chahge your isis process LEVEL2 to is-type level-1-2, because this is an area border router.
And try to use redistribution commnand in that way:
(without LEVEL2)
