POE and 1131's
May 21st, 2008
We are just starting to switch over from the 1010's to the 1131's and are curious about the AP. How many can one put on a POE switch(3560) without an injector? Do people prefer using the injectors over the POE since the 1131's use 12 W? I know they come Lwapp, so when they are installed how does one get them to talk to the WCS without using the DNS? I have a test one and used the Lwapp ap command to just send it to the controller of choice. Is there an easier way?
Thanks tons,
Overall Rating: 5 (2 ratings)
jeromehenry_2 Wed, 05/21/2008 - 23:14
Power: depends on your switch model of course, as you say the AP takes 12 W. I use PoE whenever I can, it's easier to deploy than RJ45 + power.
The APs talk to the WLC, Wireless LAN Controller, not the WCS (Wireless Control System). An easy way is to use DHCP option 43, see here http://www.cisco.com/univercd/cc/td/doc/product/wireless/airo1000/1000hig3/1000h_f.htm .
rob.huffman Thu, 05/22/2008 - 06:00
Hi Jeff,
I agree with Jerome here :) (5 points for your great tips Jerome!) The 3560 PoE can support the 1131 which is great and will save extra configs required on the WLC when using power injectors, plus save some ca$h. Have a look at this very handy tool;
Cisco Power Calculator
Hope this helps!
Sushil Kumar Katre Mon, 05/26/2008 - 10:28
Hi Jeff,
Just an update - The regular 3750s/60s are capable of providing 15.4w on all 24 ports OR the 48-port version can deliver the necessary power to support 24 ports at 15.4W, 48 ports at 7.7W, or any combination in between.
-> Sushil
