05-21-2008 09:38 AM - edited 03-11-2019 05:47 AM
Would it be possible with an ASA 5505 to have the outside and inside network and also a DMZ network and test network? I want to place a web server in the DMZ and have a dedicated test (off one of the switch ports)network for remote users to get into that is seperate from my inside network. I also want to be able to access the test network from inside. Is this possible with the asa 5505?
Solved! Go to Solution.
05-21-2008 10:14 AM
yes, security + license.
the base license allows for 3 vlans - but the 3rd vlan can only communicate with ONE of the other two VLans.
05-21-2008 10:11 AM
depends on the license. post the output of "show version" (assuming you already have a 5505 in your possession).
with the base license no, security plus license yes.
05-21-2008 10:13 AM
Don't have it yet....what license do I need for this to work?? The Security Plus one?
05-21-2008 10:14 AM
