Errors with bat on call manager 6
May 21st, 2008
Hi there,
I am trying to use BAT to check the following box on the phones
"logged into hunt group"
I do update phones and select the box and run the job.
I get the following error when we run the job
HLOGcolumn not found in table device
we get this on each phone we try to change the field on.
We are running call manager 6.1.1.2000-3
thanks
Ken
irisrios Tue, 05/27/2008 - 13:31
Create XML with column "hlog". Read the checkbox prefix device hlog dynamic and set the table name accordingly. Add this table name to the input xml that will be stored in bat input data.
