Gateway and CCM Problem
May 21st, 2008
I have a CCm 4.1 and a 2841 acting as a gateway. Also have a FXO card and in one of this port I have a direct line. I have configured a connection plar on this port to dial the number 9030 (that is my hunt group) and configured a voip dial-peer pointing to this hunt group.
But I cant make this work.
Follows my debug if anyone can help it would be great.
Thanks and best regards
Overall Rating: 4 (1 ratings)
Jaime Valencia Wed, 05/21/2008 - 21:23
that code means:
Unallocated (unassigned) number:
The ISDN number was sent to the switch in the correct format; however, the number is not assigned to any destination equipment.
u sure the GW config has a inbound CSS that can reach the DN?
is the DP pointing to the correct CUCM?
BTW, please post the questions on the related topic as this does not seem to be a Video Over IP question
if this helps, please rate
rafael.2007 Thu, 06/19/2008 - 02:36
Thanks for your support javalenc. But after alot of tests i changed the FXO board and worked. So it seems that was a bad card.
But many thanks to your reply was very helpful.
About the topic. Sorry if I put on the Video Over IP it was a mistake.
