05-21-2008 12:34 PM - edited 03-14-2019 02:15 AM
we are using UCCX 5.0.2 with a CM6.1.1.
We want to transfer a call from the uccx to a voice mail system. We do this in a script with a redirect step. Now my question:
Is ist possible to send the ANI also to the voice mail system. At the moment the voice mail system only gets the number of the uccx system.
Thank you for your help!
kind regards
alex
Solved! Go to Solution.
05-25-2008 10:20 AM
The easiest way I am aware of dealing with this is to have a CTI Port in UCM that forwards all calls to Voice Mail. That way Unity sees the correct extension matching a subscriber mailbox.
05-25-2008 10:20 AM
07-03-2008 03:39 AM
Thank you, that solved the problem!
