How to find the size of memory flash in a Pix 515 4.4(4)
Answered Question
May 21st, 2008
Hi guys,
I wanna know if is any way to find the flash memory size in a Pix 515 with PIX Version 4.4(4)
Here my show version (there is no command like show flash, dir , etc)
pixfirewall> show ver
PIX Version 4.4(4)
Compiled on Thu 06-Jan-00 16:07 by pixbuild
PIX BIOS Cisco Secure PIX Firewall BIOS
pixfirewall up 2 mins 3 secs
Hardware: PIX-515, 64 MB RAM, CPU Pentium 200 MHz
Flash strata @ base 0x300
0: ethernet0: address is 0050.54ff.4a74, irq 10
1: ethernet1: address is 0050.54ff.4a75, irq 7
Licensed Options:
Failover: Disabled
IPSec: Disabled
Ports allowed: 2
If I open the case (the case is selled), is there any indication in the memory card if the memory is 2MB/8MB/16MB ??
Thanks in Advanced,
My Best Regards,
Andre Lomonaco
Correct Answer by sundar.palaniappan about 9 years 2 months ago
Andre,
You have 16mb flash.
I know it's a little cryptic as I had been in this situation long time ago when I started using the PIX.
PIX FAQ:
Q. How do I determine how much Flash memory my PIX has?
A. If you perform a show version command on your PIX, and the Flash size is not given in MB, then use this table to see how much Flash your PIX has.
i28F020 512 KB
AT29C040A 2 MB
atmel 2 MB
i28F640J5 8 MB - PIX 506 16 MB - all other PIXes
strata 16 MB
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_qanda_item09186a0080094874.shtml
Sundar
Overall Rating: 5 (1 ratings)
Correct Answer
sundar.palaniappan Wed, 05/21/2008 - 13:55
  • Green, 3000 points or more
Andre,
PIX FAQ:
i28F020 512 KB
AT29C040A 2 MB
atmel 2 MB
strata 16 MB
Sundar
lomonaco Wed, 05/21/2008 - 16:48
Thanks a lot Sundar.
You help me a lot.
My Best Regards and thanks again
Andre Lomonaco
