Unreachable WebSite starting a VPN???
May 21st, 2008
This is an interesting one, I have several customers all behind ASA's of various OS versions. One of them needs to get to
http://www.pnreap.org/
But they cannot, it stutters along and does not load correctly. In looking at this it appears that the site is attempting to start an isakmp connection. I know this as I see it in the ASDM:
4|May 21 2008|11:44:12|713903|||IP = 75.160.107.228, Error: Unable to remove PeerTblEntry
3|May 21 2008|11:44:12|713902|||IP = 75.160.107.228, Removing peer from peer table failed, no match!
3|May 21 2008|11:44:12|713048|||IP = 75.160.107.228, Error processing payload: Payload ID: 1
Plus I have done a packet capture on the ASA, the same problem now that I know to check is happening on all the ASAs, identically.
Now the troubling part is if I attempt to go to this website when not behind an ASA it works very well. I had thought perhaps mss or something but the packet trace reveals differently, does anyone have any ideas?
