IKE Does Not Start
May 21st, 2008
I have an ASA5510. When I put the command 'crypto map MAP 20 set peer a.b.c.d', an error message "[IKEv1]: Ignoring msg to mark SA with specified coordinates <MAP, 20> dead" comes out. What does this mean?
When I turned out debug crypto isakmp 127, no messages come out.
How can I start IKE?
Thanks in advance.
alanajjar Wed, 05/21/2008 - 21:24
I am not sure about your full configuration, but if you want to enable ISAKMP on a specific intrface use the command:
Crypto isakmp enable interface_name
The ISAKMP should start when you define this, if this is not the case, post your config, and make some debugging, for isakmp and ipsec.
Chuan Liu Thu, 05/22/2008 - 12:20
It starts working after a reload.
Thanks for your response
