Cisco 831 and AT&T DSL
May 21st, 2008
Hi all.
I have a 2wire DSL router configured as a layer 2 bridge and directly connected to it is a Cisco 831.
I would like to have the Cisco 831 running as a PPPoE client for the DSL connection and NAT for my LAN.
However, I cannot get my configuration to work.
When I place a Linksys WRT54G behind the bridge, it connects via PPPoE with no problems but I would really like to place the 831 on the outside of my LAN.
debug pppoe events on the 831 (directly connected to the bridge) shows the following repeating loop:
Mar 31 : Sending PADI: Interface = Ethernet1
Mar 31 : padi timer expired
Any help debugging the bba-group, vpdn and interface configurations would be very appreciated.
Current configuration : 4650 bytes
version 12.4
no service pad
service password-encryption
hostname Cisco831
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.10.1
ip dhcp pool sdm-pool
import all
network 10.10.10.0 255.255.255.248
default-router 10.10.10.1
lease 0 2
ip cef
ip domain name yourdomain.com
vpdn enable
vpdn-group 1
request-dialin
protocol l2tp
domain global
username xxxxxxxx privilege 15 secret xxxxxxxx
bba-group pppoe global
virtual-template 1
interface Ethernet0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-Ethernet 10/100$
ip address 10.10.10.1 255.255.255.248
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1412
interface Ethernet1
description $ETH-WAN$
no ip address
ip mtu 1492
ip nat outside
duplex auto
pppoe enable group global
pppoe-client dial-pool-number 1
interface Ethernet2
no ip address
shutdown
interface FastEthernet1
duplex auto
speed auto
interface FastEthernet2
duplex auto
speed auto
interface FastEthernet3
duplex auto
speed auto
interface FastEthernet4
duplex auto
speed auto
interface Dialer0
ip address negotiated
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname xxxxxxxx
ppp chap password xxxxxxxx
ppp pap sent-username xxxxxxxx password xxxxxxxx
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface Dialer0 overload
access-list 1 permit 10.10.10.0 0.0.0.7
dialer-list 1 protocol ip permit
line con 0
login local
no modem enable
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
end
Sam Smiley Wed, 08/10/2016 - 05:46
It has been a really long time since I have used AT&T DSL, I was able to find an old 831 config for you. This was a working config when this device was in use.
Sam
