EM query
May 21st, 2008
We have implemented Extension mobility and client requires following features,
- While logging out from EM, it should not display username.
- Force system to logout IDLE connections after 3 hrs.
We would like know how to implement these features.
Jaime Valencia Wed, 05/21/2008 - 21:01
change the service parameter:
Enforce Maximum Login Time
to make them logout after 3 hours, there is no parameter to have this happen after IDLE time. after 3 hours the phone will logout
i don't believe there is a way to modify the messages displayed on the phone during login or logout process
other than that i could only think of having a dev support contract and check with them if they can change the service scripts
if this helps, please rate
tanmaydevare Wed, 05/21/2008 - 21:05
Hi javalenc,
Thanks for your prompt reply. We are already aware of "Enforce Maximum Login Time" parameter but we were also wondering abt IDLE connection timeout. Can u verify the same and revert back.
Jaime Valencia Wed, 05/21/2008 - 21:15
what do you consider as idle??
not making calls?
not pressing any button?
not taking the phone off-hook?
