Can't get 871w to work - traffic doesn't pass from fa0-3 to wan fa4
May 21st, 2008
I'm going crazy! I've looked all around the internet using sample configs and I can't get going (I'm new to Cisco).
I can hookup the Wan fa4 to my linksys router, it picks up a dhcp ip and I can ping that. I can't ping the fa0-3 ports (when I assigned an ip for them), Vlan1 (when I assigned an IP to that), or the BVI1. I can ping these from in the router itself. Also, it doesn't hand out IP's from the assigned dhcp pool, it gives out 192.168.1.x address which is from the linksys (these 192.168.1.x can't ping anything) when it should be handing out 10.20.0.x addresses. I hooked up the cable modem directly to the 871w and rebooted the router, but it still handed out 192.168.1.x address.
Please can someone point me in the right direction?
Thanks a million!!!!!
Building configuration...
Current configuration : 3612 bytes
version 12.4
no service pad
hostname Digital
boot-start-marker
boot-end-marker
no logging buffered
enable secret xxx
no aaa new-model
resource policy
clock timezone MDT -7
clock summer-time MDT date Apr 6 2003 2:00 Oct 26 2003 2:00
--More-- ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.20.0.1 10.20.0.50
ip dhcp pool Internal-net
import all
network 10.20.0.0 255.255.255.0
default-router 10.20.0.1
domain-name bxxxxx.com
no ip domain lookup
ip domain name cisco.com
crypto stuff ----
quit
username xxxxx privilege 15 password 0 xxxxxx
bridge irb
interface FastEthernet0
spanning-tree portfast
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
ip address dhcp
--More-- ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface Dot11Radio0
no ip address
shutdown
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Vlan1
no ip address
ip nat inside
bridge-group 1
bridge-group 1 spanning-disabled
interface BVI1
description Bridge to Internal Network
ip address 10.20.0.1 255.255.255.0
ip nat inside
--More-- ip virtual-reassembly
ip classless
ip route 0.0.0.0 0.0.0.0 dhcp
ip http server
ip http authentication local
ip http secure-server
ip nat inside source list 1 interface FastEthernet4 overload
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 10.20.0.0 0.0.0.255
control-plane
bridge 1 route ip
left off the rest
mbevington Wed, 05/21/2008 - 22:17
I checked SDM and they are all Vlan1.
Should I put this in "by hand"?
mbevington Thu, 05/22/2008 - 05:26
Ok, I put it in by hand - looks like nothing changed.
What else could be wrong?
Thanks!
mbevington Thu, 05/22/2008 - 16:51
Still having the same problem.
Somehting new though - I'm seeing an NVI0 interface popping up: it wasn't before. Is this the problem?
