integrate Active directory 2003 with Cisco Call Manager 5.1.3
May 21st, 2008
Can anyone tell us to integrate Active directory 2003 with Cisco Call Manager 5.1.3
We are very new to this areana. hence please guide us if its possible to make it.
Thanks in advance
Overall Rating: 3 (1 ratings)
anva12345 Wed, 05/21/2008 - 23:44
Thanks for the link.
Could you please help us to identify the correct AD plugin for 2003 server in Cisco Call manager 5.1 running windows as well as other avaialble platform.
Thanks in advance
Jaime Valencia Thu, 05/22/2008 - 08:00
  • Cisco Employee,
  • Hall of Fame,
    2011
CUCM 5.x/6.x are linux and do not require any plugin just follow the instructions from the link, plugins for AD are for windows releases.
and the plugin you need is specific for each version, go to the plugins page and download it from there. use it only for that cluster.
Active Directory 2000 Plugin Installation for Cisco CallManager
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080094493.shtml
Installing and Configuring the Cisco Customer Directory Configuration Plugin
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/install/3_0/ad_3011.html
javalenc
if this helps, please rate
anva12345 Tue, 06/03/2008 - 20:41
Thanks and Sorry for the delay in reply.
As u mentioned in your previous mail CUCM 5.x/6.x are linux and do not require any plugin for integrate with ADS.
Could you please give us the link which helps us to configure . the above given links seems to be windows based CM instructions.
Waiting for your reply. thanks in advance
