How to load a file containing users and attributes
May 22nd, 2008
I've an Access Control Server Solution Engine 1113 vers 4.0. Is there a method for loading a file with users (40.000) and their attributes (IP address, DNS server and so on...)?
I know that for ACS (not for solution engine) there is an util (csutil.exe) for doing this loading...but for engine how can I do?
Thank you for your reply.
Best regards.
Massimiliano.
Overall Rating: 4.3 (3 ratings)
darpotter Thu, 05/22/2008 - 05:35
You can, its called rdbms sync and theres a fair amount of good info in the ACS docs.
You build a csv transaction file containing actions to add a user, set password, group etc etc. You can assign radius & tacacs attribute values too. From the ACS appliance web UI you upload the csv via FTP then it gets processed.
It covers about 90% of ACS functionality so you may not be able to set everything you need.
docs are here:
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_server_for_windows/4.1/user/A_RDBMS.html
