First time setup of 1841 / No access via SDM
CNTSYSNETAG
I set up my Cisco 1841 and I try to access the device using SDM. SDM seems to be installed on the Cisco 1841 ("Cisco Router and Security Device Manager (SDM) is installed on this device."), but it is not possible to access the device via SDM. I started the SDM launcher on my PC, entered the IP address of the Cisco, then a new window opens in my browser saying "Application will open in another window. If you wish, you can close this window.", but then nothing happens. I can ping the Cisco from my PC and I can ping the PC from the Cisco. Here is the current config:
abc-gw#show running-config
Building configuration...
Current configuration : 2467 bytes
version 12.4
hostname abc-gw
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret xxx
enable password xxx
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip domain name yourdomain.com
username cisco privilege 15 secret xxx
interface FastEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0$
ip address 192.168.4.20 255.255.255.0
speed auto
full-duplex
no mop enabled
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/0/0
shutdown
interface FastEthernet0/0/1
shutdown
no mop enabled
interface FastEthernet0/0/2
shutdown
interface FastEthernet0/0/3
shutdown
interface Vlan1
no ip address
shutdown
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.4.1
ip http server
ip http access-class 23
ip http authentication local
ip http timeout-policy idle 60 life 86400 requests 10000
access-list 20 permit 0.0.0.0 255.255.255.0
access-list 23 permit 10.10.10.0 0.0.0.7
access-list 23 permit 0.0.0.0 255.255.255.0
dialer-list 1 protocol ip permit
control-plane
banner login ^C
This feature requires the one-time use of the username "cisco"
with the password "cisco". The default username and password have a privilege level of 15.
Please change these publicly known initial credentials using SDM or the IOS CLI.
Here are the Cisco IOS commands.
username <myuser> privilege 15 secret 0 <mypassword>
no username cisco
Replace <myuser> and <mypassword> with the username and password you want to use.
For more information about SDM please follow the instructions in the QUICK START
GUIDE for your router or go to http://www.cisco.com/go/sdm
^C
line con 0
login local
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
password )(!!,mqp!75
login local
transport input telnet
line vty 5 15
access-class 23 in
privilege level 15
login local
end
Any idea why I cannot access the device using SDM?
Wantser1981_2
Your http access list (ACL 23) is incorrect.
I take it your machine is on the 192.168.4.x/24 network?
If so you need to allow
permit 192.168.4.0 0.0.0.255
You are currently matching against the network 10.10.10.0/29 and anything with a x.x.x.0 address which is invalid. Failing that remove "ip http access-class 23".
Also, I would enable ip http secure-server. I think SDM will require this from memory.
Andy
Thank you! Now it works.
