Ether Channel Between Cisco 4507R Switch and Non Cisco Firewall
May 22nd, 2008
Is it possible to do a Etherchannel Between Cisco 4507R Switch and Non Cisco (Juniper) Firewall, as Juniper Firewall has Aggregate Interface Option
Regards/Asfar
Pravin Phadte Thu, 05/22/2008 - 02:29
  • Silver, 250 points or more
Yes its possible.As long as you use the IEEE standard on cisco switch.
Wantser1981_2 Thu, 05/22/2008 - 02:39
Use LACP channeling not PAgP which is Cisco proprietary.
Instead of "channel-group N mode on", use "channel-group N mode active" or channel-group N mode passive".
Andy
asfar.zaidi Thu, 05/22/2008 - 07:56
Can you please check this config
interface range gigabitethernet 5/6 - 7
channel-group 2 mode active
end
interface gigabitethernet 5/6
switchport mode trunk
interface gigabitethernet 5/7
Is that enough.
Amit Singh Thu, 05/22/2008 - 08:31
  • Cisco Employee,
That's fine. You should be good to go with this config. Make sure that you configure the juniper firewall ports as the L2 trunks also.
-amit singh
