ASA support SMTP proxy?
May 22nd, 2008
Does ASA support SMTP proxy? i am not sure if this is the right term but what i mean is like the cyberguard fw where they are entering all the valid email ids on the device and the firewall will not forward the packet to the smtp server if the email id is not one in the list.
Overall Rating: 3 (1 ratings)
vitripat Thu, 05/22/2008 - 07:00
If I'm correct, you need to configure ASA such that some specific email-ids only should be allowed to send mails through ASA.
You can do this on ASA, here is a example where only 3 email-ids are allowed to send mails through ASA ([email protected], [email protected], [email protected]):
regex user1 "[email protected]"
regex user2 "[email protected]"
regex user3 "[email protected]"
class-map type regex match-any allowed-senders
match regex user1
match regex user2
match regex user3
policy-map type inspect esmtp filter-senders
match not sender-address regex class allowed-senders
reset log
match ehlo-reply-parameter others
policy-map global_policy
class inspection_default
service-policy global_policy global
Here is a link which you can refer to:
Hope this helps.
