Cisco VPN Concentrator Console cable PIN configuration
May 22nd, 2008
Can any one share Cisco VPN Concentrator Console cable PIN configuration , as I am getting hard time to find it.
Thanks in advance
Overall Rating: 5 (1 ratings)
JORGE RODRIGUEZ Thu, 05/22/2008 - 15:36
  • Green, 3000 points or more
You can simply use standard straigh through CAT5 cable and use TWO DB-9 RS-232 female serial adapter to console to concentrator one DB-9 for concentrator and the other for other end PC or Laptop etc...
http://www.cisco.com/en/US/docs/security/vpn3000/vpn3000_47/quick/guide/gs2inst.html#wp998597
If you are looking for pin outs to make CAT 5 straigh through bellow is the pin outs for each end.
Pin 1 WH/OR
Pin 2 OR/WH
Pin 3 WH/GR
Pin 4 BL/WH
Pin 5 WH/BL
pin 6 GR/WH
pin 7 WH/BR
pin 8 BR/WH
pin outs for standard Serial RS-232
http://www.camiresearch.com/Data_Com_Basics/RS232_standard.html
Rgds
-Jorge
