Not encrypted dot1x packet from 0012.f0b9.87c3 has been discarded
Answered Question
May 22nd, 2008
I have a very basic config to setup wireless on on an 857W router.
When I get connected the log fills up the the following message.
What is causing this?
Config below
version 12.4
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
dot11 ssid TESTSSID_1
vlan 10
max-associations 10
authentication open
authentication key-management wpa
wpa-psk ascii 0 mywpapskpwd
dot11 ssid TESTSSID_2
vlan 20
max-associations 10
authentication open
wpa-psk ascii 0 mytestpassword
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.100.1
ip dhcp pool HOME_1
network 192.168.100.0 255.255.255.0
default-router 192.168.100.1
ip dhcp pool HOME_2
network 10.20.0.0 255.255.255.0
default-router 10.20.0.3
ip cef
archive
log config
hidekeys
bridge irb
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
dsl operating-mode auto
interface FastEthernet0
interface FastEthernet1
spanning-tree portfast
interface FastEthernet2
interface FastEthernet3
interface Dot11Radio0
no ip address
no ip route-cache cef
no ip route-cache
encryption vlan 10 mode ciphers tkip
encryption vlan 20 mode ciphers tkip
broadcast-key change 60
ssid TESTSSID_1
ssid TESTSSID_2
speed basic-1.0 basic-2.0 basic-5.5 basic-6.0 basic-9.0 basic-11.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0
channel 2452
station-role root
world-mode dot11d country GB both
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0.10
encapsulation dot1Q 10 native
no ip route-cache
bridge-group 10
bridge-group 10 subscriber-loop-control
bridge-group 10 spanning-disabled
bridge-group 10 block-unknown-source
no bridge-group 10 source-learning
no bridge-group 10 unicast-flooding
interface Dot11Radio0.20
encapsulation dot1Q 20
no ip route-cache
bridge-group 20
bridge-group 20 subscriber-loop-control
bridge-group 20 spanning-disabled
bridge-group 20 block-unknown-source
no bridge-group 20 source-learning
no bridge-group 20 unicast-flooding
interface Vlan1
ip address 10.7.12.219 255.255.255.0
interface Vlan10
no ip address
ip virtual-reassembly
ip tcp adjust-mss 1400
bridge-group 10
hold-queue 100 out
interface Vlan20
no ip address
bridge-group 20
hold-queue 100 out
interface BVI10
ip address 192.168.100.1 255.255.255.0
ip nat inside
interface BVI20
ip address 10.20.0.3 255.255.255.0
ip nat inside
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.7.12.254
no ip http server
no ip http secure-server
control-plane
bridge 10 protocol ieee
bridge 10 route ip
bridge 20 protocol ieee
bridge 20 route ip
line con 0
no modem enable
line aux 0
line vty 0 4
login
scheduler max-task-time 5000
end
Router#
Correct Answer by Scott Fella about 9 years 1 month ago
What I would do next is look at the driver on the device and see if it is up to date or at least not to far off. Does look like a WPA issue like the other member mentioned.
Overall Rating: 5 (2 ratings)
owillins Wed, 05/28/2008 - 05:10
  • Silver, 250 points or more
I think your experiencing issues with WPA . Recycling the AP is the one way of avoiding this error.
simplecisco Wed, 05/28/2008 - 05:13
I have rebooted this box many times always get the error logged - what is the alternative to WPA?
Scott Fella Wed, 05/28/2008 - 06:14
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
Check how your client device is setup. Is it a windows device?
simplecisco Wed, 05/28/2008 - 06:22
Yes - it is windows xp sp2
Network authentication WPA-PSK
Data Encryption TKIP
Which I am sure is all correct.
Correct Answer
Scott Fella Wed, 05/28/2008 - 06:35
  • Hall of Fame,
    2017 Wireless
simplecisco Wed, 05/28/2008 - 06:51
That has fixed it! The simple ones are always the trickiest to fix.
thanks for the advice, updated the wireless driver on my laptop and no more errors.
Roger
Scott Fella Wed, 05/28/2008 - 06:54
  • Hall of Fame,
    2017 Wireless
Too funny... I get clients complain to me about issues and they have drivers that are from 2003 or 2004.
Now all you have to do is make sure all other devices are on the same firmware. Makes troubleshooting sooooooo much easier.
simplecisco Wed, 05/28/2008 - 06:54
Ooops - now it hasn't the errors have just started up again..
Scott Fella Mon, 06/02/2008 - 04:47
  • Hall of Fame,
    2017 Wireless
Thanks for the info on the fix. Always good to know.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
