%PIX-3-305006: Regular translation creation failed
May 22nd, 2008
I'm getting this error even if the IP addresses used for NAT are correct, not network or a broadcast address.
My platform:
Cisco PIX Firewall Version 6.3(5)
Cisco PIX Device Manager Version 3.0(4)
My network is connected with MPLS links. If I ping from another site (another network) I get a reply and no error messages logged. Other networks reach my site from the inside interface via MPLS router. If I ping from inside to the inside address of the server, natted from the dmz, I get the above error logged and no response.
static (dmz,inside) MAIL_inside MAIL_dmz netmask 0 0
net remote : /24
net local : /24
dmz: /24
Remote network is connected via MPLS router.
I ping the ip address in local network from remote network, I reach the server, real address
If I ping from a machine in my local network the ip address of the server I can't get any response!
Hope my explanation is clear.
Any hint? Thanks
vitripat Thu, 05/22/2008 - 07:42
I think you dont have a corresponding nat/global commands for network to go to dmz network.
Assuming that you have following nat statement:
nat (inside) 1
global (dmz) 1 interface (try this command)
If this does not help, please past outputs of "show nat" and "show global" commands.
Gian Paolo Boarina Mon, 05/26/2008 - 05:56
That's right, global(dmz) statement is missing.
Is it correct that with this configuration I can reach the natted IP from other networks, coming from a MPLS router connected to inside interface , but not from the network the inside interface belongs to?
