VPN Remote Client Unable to Ping network Devices
May 22nd, 2008
I have an ASA 5505 setup for VPN remote access. I have 3 users setup the same. Two users are able to get in and view devices on the network. The third user is able to connect to the router but cannot ping anything on the inside. Any ideas?
hill.kevin Sat, 05/31/2008 - 20:26
I have been able to log on with that users credentials. I have noticed that, even with my credentials, there are some locations that allow me to log on but not allow access to the internal network. Could it be restrictions from equipment at the remote locations?
Kevin
hill.kevin Mon, 06/02/2008 - 12:19
Can you tell me what kinds of things they might be blocking that would cause this issue?
Kevin
jcarrillo6 Sun, 06/01/2008 - 06:28
One possibility could be that the user has a multihomed nic. Make sure he only has one IP address on the cleint machine. if there are other IP addresses on a different network, the proxy addresses will not match.
