WebVPN timers
Answered Question
May 22nd, 2008
I've set up WebVPN to allow access to Citrix servers, it works fine, but the problem is that when the user closes the session and IE window, the ASA keeps the WebVPN session open for 30mins.
Is there any way to cut dowm this timer, as its a security and resources problem.
I've looked using the ADSM but can't find a setting.
Any help appreciated
Regards Tony
Overall Rating: 5 (1 ratings)
tholmes@cistek-... Thu, 05/22/2008 - 09:12
Actually you put me on the right track, there are numerous commands in CLI not shown on the ASDM.
There is a WebVPN sub-command for 'defaul-idle-timeout' which has a default of 30mins!
Many thanks for your reply
