05-22-2008 07:13 AM
I am trying to enable the Netflow on the above mentioned switch with no luck. Please find let me know what am I missing .HW and the configuration details in the attachment.
Thanks in advance,
subra
Solved! Go to Solution.
05-22-2008 08:54 AM
which ports do you mean?
Could you set quicker timeout in the IOS:
ip flow-cache timeout active 2
ip flow-cache timeout inactive 24
Kind regards
Jan Nejman
Caligare, Co.
05-22-2008 08:05 AM
I checked your configuration and the problem is in CatOS part.
remove the line:
set mls nde flow include destination 192.168.1.19/255.255.255.255
If it doesn't help, please, send me the following:
MSFC:
show ip flow export
show ip cache flow
Supervisor:
show mls nde
Kind regards,
Jan Nejman
Caligare, Co.
05-22-2008 08:45 AM
Thanks for your immediate response.
Here is the weird part. Now I get for some of the ports(2 ports are missing) in the Vlan 1 and Vlan 80 but no Vlan 30.
GW#sh ip flow export
Flow export is enabled
Exporting flows to 192.168.1.19 (2055)
Exporting using source interface Vlan1
Version 5 flow records
2258 flows exported in 271 udp datagrams
0 flows failed due to lack of export packet
0 export packets were sent up to process level
0 export packets were dropped due to no fib
0 export packets were dropped due to adjacency issues
0 export packets were dropped due to fragmentation failures
0 export packets were dropped due to encapsulation fixup failures
0 export packets were dropped enqueuing for the RP
0 export packets were dropped due to IPC rate limiting
GW#sh ip cache flow
IP packet size distribution (12641 total packets):
1-32 64 96 128 160 192 224 256 288 320 352 384 416 448 480
.000 .547 .261 .079 .000 .000 .000 .052 .005 .000 .019 .000 .000 .000 .000
512 544 576 1024 1536 2048 2560 3072 3584 4096 4608
.000 .000 .033 .000 .000 .000 .000 .000 .000 .000 .000
IP Flow Switching Cache, 278544 bytes
10 active, 4086 inactive, 2260 added
45559 ager polls, 0 flow alloc failures
Active flows timeout in 1 minutes
Inactive flows timeout in 15 seconds
last clearing of statistics 00:59:52
Protocol Total Flows Packets Bytes Packets Active(Sec) Idle(Sec)
-------- Flows /Sec /Flow /Pkt /Sec /Flow /Flow
TCP-Telnet 7 0.0 156 40 0.3 25.8 11.9
TCP-other 49 0.0 1 48 0.0 7.1 15.4
UDP-other 1604 0.4 2 168 1.1 3.0 15.3
ICMP 602 0.1 12 67 2.0 9.5 13.1
Total: 2262 0.6 5 98 3.5 4.9 14.7
SrcIf SrcIPaddress DstIf DstIPaddress Pr SrcP DstP Pkts
Vl1 0.0.0.0 Null 255.255.255.255 11 0044 0043 6
Vl1 10.22.6.25 Local 10.22.1.1 01 0000 0800 1
Vl1 10.22.7.2 Null 10.22.255.255 11 008A 008A 2
Vl1 10.22.7.2 Null 10.22.255.255 11 0089 0089 15
Vl1 10.22.5.13 Null 10.22.255.255 11 008A 008A 1
Vl30 192.168.2.72 Local 10.22.1.1 06 0788 0017 56
Vl1 10.22.2.7 Null 10.22.255.255 11 008A 008A 1
Vl30 192.168.1.101 Null 10.22.2.17 11 12E7 00A1 2
Vl30 192.168.1.101 Null 10.22.2.8 11 12E7 00A1 2
Vl80 10.24.15.12 Local 10.24.15.1 01 0000 0800 27
GW#
CAT> (enable) sh mls nde
Netflow Data Export version: 5
Netflow Data Export enabled
Netflow Data Export configured for port 2055 on host 192.168.1.19
Secondary Netflow Data Export port/host is not configured.
Total packets exported = 47
Total Secondary packets exported = 0
Total NDE collectors configured = 1
Destination Ifindex export is enabled
Source Ifindex export is enabled
Bridged flow statistics is enabled on vlan(s) 1,30,80.
Bridged flow statistics is disabled on vlan(s) 1002-1012,1016.
Thanks again.
subra
05-22-2008 08:54 AM
Kind regards
Jan Nejman
Caligare, Co.
05-23-2008 12:57 AM
Hi Jan,
Thanks for the help. Got it Fixed.
Subra
