ASA/PIX : Telnet or ssh using hostname instead of IP for authentication
We are trying to use this command:
instead of
telnet inside
but the command is not working. Is there some other sytax that we need?
Here is what the ? says from the asa:
ASA(config)# ssh ?
configure mode commands/options:
Hostname or A.B.C.D The IP address of the host and/or network authorized to
login to the system
X:X:X:X::X/<0-128> IPv6 address/prefix authorized to login to the system
scopy Secure Copy mode
timeout Configure ssh idle timeout
version Specify protocol version to be supported
rochopra Fri, 05/23/2008 - 00:48
you need to specify the following commands:
telnet inside
hope this helps.
