WCS 5.0.56.0 - Where is AP-Groups VLAN feature?
May 22nd, 2008
I have 4 AP Groups (WLC: WLANs/Advanced/AP Groups VLAN) setup to limit what SSIDs each AP serves. These all show up as mismatches in WCS. I cant find any template available to configure these in WCS nor can I "Refresh Controller Values" to fix it. Any ideas? Is this a feature they forgot in WCS?
Versions: WCS:5.0.56.0 & WLC:5.0.148.0
jeromehenry_2 Fri, 05/23/2008 - 02:15
  • Silver, 250 points or more
Yes, that's strange. You can configure an AP template so that APs a re part of the AP group VLAN, but the group itself doesn't show anymore in the controller templates. You can still configure it on each controller individually.
When auditing a controller (config controllers, select the one to audit -> audit now / Go), I can still see refresh controller values or restore WCS values..
hth
J
krengasw Sat, 05/31/2008 - 23:30
  • Cisco Employee,
In WCS,there is no template option available to configure AP group vlan.But you can configure via WCS:
1)GO TO configure>controllers.click controller name link.
2)CLICK WLAN on left hand side.YOU WILL FIND AP group vlan.
3)Now configure AP group vlan-by adding group and select ssid want to serve for each vlan.
This will save directly to wlc.
I hope this will resolve your problem.
Kannan
Hey folks,
Please correct me if I'm wrong, but doesn't AP Groups VLAN simply re-map the interface of the SSID from the defualt interface definition under the WLAN? I don't believe it restricts what SSIDs/WLANs are advertized by the Access Point - this has to be performed at the AP or via an AP Template. Is this a new feature of APG in 5.0?
Thanks for any clarification,
--Bruce Johnsom
jeromehenry_2 Mon, 06/02/2008 - 01:04
You are right Bruce, the issue described in this thread is a combination of WLAN override, to decide which SSID is advertized by an AP, and AP group VLAN, to decide which interface / which VLAN tag traffic comming from a given SSID on a given AP will receive...
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
