two inside interfaces talking to one another?
May 22nd, 2008
I am trying to get 2 inside interfaces on a PIX 515E to talk to one another. (These networks need to have any-any type connectivity to each other)
I know on 7.X all you should have to do is create them with the same security level and do a:
same-security-traffic permit inter-interface
However, I am running 6.3 and cant upgrade due to memory to 7.X
Here is what I have
ETH0 Outside interface (nat pool) security level 0 (X.X.X.X - Outside/Internet)
ETH1 Inside interface security level 100 ( (Inside space 1)
ETH1 Inside2 interface (VLAN3) security level 99 ( (Inside space 2)
I can get the inside (192.168.5.X) to talk to inside2 (192.168.6.X) by doing a
access-list inside_outbound_nat0_acl permit ip
nat (inside) 0 access-list inside_outbound_nat0_acl
But I can't for the life of me get inside2 (192.168.6.X) to talk to inside (192.168.5.X)
Overall Rating: 4 (1 ratings)
Try the below
static (Inside2,Inside) netmask
access-list inside2_outbound_nat0_acl permit ip
nat (inside2) 0 access-list inside2_outbound_nat0_acl
And of course - if as Inside2 will have a lower security level - make sure you are allowing via and ACL traffic from Inside2 to Inside?
davistw Tue, 05/27/2008 - 10:44
Thanks for the pointer...
What I ended up doing was:
access-list inside2_vlan3_access_in permit ip
access-group inside2_vlan3_access_in in interface inside2_vlan3
static (inside,inside2_vlan3) netmask
access-list inside2_vlan3_access_in permit ip any
