05-22-2008 08:26 AM - edited 03-15-2019 10:49 AM
I am doing a CUCM 6.1 install with 2821 voice gateway...instead of PRI we will be getting SIP trunk delivered over MPLS from global crossing...does anyone have any info on configuring SIP trunks over MPLS
thanks
Solved! Go to Solution.
05-29-2008 05:27 AM
G711 is the only available codec on SIP trunk until CM 7.0 due this fall. You should be able to use transcoders on the IPIP GW if you need to send the call as G729 to the privider.
Chris
05-22-2008 01:24 PM
One the 2821 you will need to run the CUBE feature, aka ip-to-ip GW, go over the admin guide and I think most cases are covered in there.
05-29-2008 05:09 AM
thanks for the help...we actually did a SIP trunk to the call manager 6.1..the codec on the SIP trunk is 711 and is greyed out...cant change it....can I use 729 or any other codec
thanks
Colum
05-29-2008 05:27 AM
Chris
05-29-2008 05:29 AM
thanks Chris
06-04-2008 05:51 AM
cant you use G729 via the region setting?
