05-22-2008 08:35 AM - edited 03-15-2019 10:49 AM
I have a call manager 5.1 and I need to do the upgraded but I have doubts about two version cisco-ipt-k9-patch5.1.3.2000-3.tar.gz.sgn and
cisco-ipt-k9-patch5.1.3.3000-5.tar.gz.sgn what is the different between both?.
The reason of this upgraded is why my current version have this bug that is shows below:
CSCsk86705 Bug Details
ForwardAll CFA removed from CCMUser page .
Symptom:
Call Forward All / Forward All / FwdAll / CFA not available in CCMUser page.
Conditions:
CM 5.1(3) with Enterprise parameter 'Show Call Forwarding' Enterprise Parameter set True.
Workaround:
None.
Further Problem Description:
There were supposed to be 3 options for Enterprise Parameter 'Show Call Forwarding' Enterprise:
True, False, Show Only Forward All.
Can somebody tell me advantage disadvantage of this two versions?
05-22-2008 08:39 AM
just the release:
note the numbers after 5.1.3, 3000-5 is a later release.
i'd install the latest as it probably has more bugs resolved
if you want the whole list of fixes you can go thru the readme files
javalenc
if this helps, please rate
05-22-2008 08:39 AM
Read the release notes for both. These are available at the same place you downloaded the files from at CCO. The release notes tell what bugs are fixed in each version.
Of course 3000.5 has more bug fixes than 2000.3. 3000.5 should "technically" include all the previous bug fixes that were included in an earlier release like 2000.3.
You should also be careful about what it could possibly break. We are lucky that you can switch between old and new versions with CM 5.x and 6.x if some feature breaks after the upgrade.
