871 Basic Setup Instructions
May 22nd, 2008
Hi all. I am completely new to Cisco Routers. before i had the Linksys WRV 200 and all i had to do is enter a static DSL IP, Mask, Gateway(the Routers IP) and DNS
Here on the 871 i can't even get the internet working correctly.
I have read some posts that people are setting up the Routers from the command line. Can i set it up from the SDM interface?
Please someone explain to me and maybie describe a simple setup where my Public Static (Internet) IP is , DNS , Net IP and my private network which i have on a Hub that connects to the ETH0 of the router begins from and goes untill 200
Please if it's not too much trouble explain to me how this is done. I have no idea what to do here so any description would be VERY helpful. If someone could explain to me and guide me through on how to do this and NOT redirect me to a link that would be very helpful.
Once again TNX in advance.
fgcity4652 Thu, 05/22/2008 - 22:54
OK, below is my configuration. Please tell me what is wrong with it.
This is all new to me so please help out.
I have just reset the Router and added the basic settings that the wizard asked me.
Attached is my Config
husycisco Fri, 05/23/2008 - 11:34
Hi Demetris,
You have assigned your Public ip to a fastethernet interface. That wont work. Add the following in your config
no interface FastEthernet4
interface ATM0
no ip add
no shu
dsl operating-mode auto
interface ATM0.10 point-to-point
pvc 0/100
pppoe-client dial-pool-number 1
interface Dialer0
no shu
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp pap sent-username password 7
no ip route FastEthernet4
ip route dialer0
no ip nat inside source list 1 interface FastEthernet4 overload
ip nat inside source list 1 interface dialer0 overload
Then post your new config and let me check if missing conf exists
fgcity4652 Sun, 05/25/2008 - 22:22
Tnx for the reply. I will try this but before i do i want to ask:
why do i have to set a Dialer? and what Username and Password should i enter?
My connection is ADSL. So the ADSL modem is already connected. So what am i doing here?
