IP Source Guard BUG or Poor documentation?
May 22nd, 2008
I'm using 3750G switches in my network and have a few server NIC Teamed to the 3750G stack with LACP.
I read under http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_44_se/configuration/guide/3750SCG.pdf
that "IP source guard is not supported on EtherChannels."
But when I go to the Port-channel interface for my LACP bond, I am able to setup IP Source Guard and it shows active .
interface Port-channel1
description "LACP to xxxx g1/0/1 & g2/0/1"
switchport access vlan 20
switchport mode access
spanning-tree portfast
spanning-tree bpduguard enable
ip verify source
end
ip source binding 0019.B9EA.xxxx vlan 20 10.80.20.10 interface port-channel 1
show ip verify source
Interface Filter-type Filter-mode IP-address Mac-address Vlan
Po1 ip active 10.80.20.10 20
Is this a BUG or documentation needs to be updated?
didyap Wed, 05/28/2008 - 08:55
When configuring IP source guard on interfaces on which a private VLAN is configured, port security is not supported" - I assume that this means "switchport protected", I attempted disabling it but it did not do anything. On the other hand, interface is configured with the feature turned on and it works fine.
