Speed Dials on phones
Answered Question
May 22nd, 2008
This is a silly question but when I set up speed dials on a 7970 in phone configuration in callmanager the speed dials don't show up on the phones, am I missing something? Thanks in advance
Correct Answer by rob.huffman about 8 years 8 months ago
Hi Efrain,
Only if the Phone Button Template for the 7970 is set up as 1-Line and 7-Speed Dials. I'm not on site right now so I can't check but I don't think the default Button Template is set up as such. If not you will need to create a new Phone Button Template with the 1-Line 7-Speed Dial combination.
Rob
Overall Rating: 5 (1 ratings)
rob.huffman Thu, 05/22/2008 - 11:20
Hi Efrain,
Have you checked the Phone Button Template being used for the 7970 to be sure that it can accomodate the number of Speeddials you are assigning? Also using Save and Close then resetting the phone?
Rob
gonzalezel Thu, 05/22/2008 - 11:35
They are in there, they are just not associated with any of the line buttons I have, I have 8 lines and my primary line so I should be able to have speed dials on the other 7 lines right?
Correct Answer
rob.huffman Thu, 05/22/2008 - 11:45
Hi Efrain,
Rob
gonzalezel Thu, 05/22/2008 - 11:51
Thanks Rob that solved my issue it isn't set up for speed dials just 8 lines.
rob.huffman Thu, 05/22/2008 - 16:10
Hi Efrain,
You are most welcome my friend! Were you able to get this fixed up? I think users really love these type of Speed Dials!
Rob
