How i can upgrade my asa to 8.0?
May 22nd, 2008
I have asa 5520 with software ver 7.2 & vpn+ licens
How i can upgrade to 8.0?
I think if i download new soft from then download them to asa flash & reload with this new image - then all it's ok, but what about license?
How i can incert my licens to new software?
Overall Rating: 3 (3 ratings)
vitripat Thu, 05/22/2008 - 11:13
You just need to download 8.x image, copy to flash, set ASA to boot from the new image and reload the ASA.
copy tftp flash (to copy image from tftp server)
no boot system
boot system
Need not worry about license, it will remain same.
Hope that helps.
stojanr Thu, 05/22/2008 - 12:29
All commands from ASA 7.2 will work fine in 8.0 version.
suschoud Thu, 05/22/2008 - 12:33
the change in command format from 7.x to 8.x is automatically done during the upgrade.also,the new default fatures in 8.x are also added.also,please be aware that as 8.x is a bigger image with many more features,the memory consumption of your f/w would increase to a considerable amount.this is normal for any upgrade to 8.x.
Gian Paolo Boarina Mon, 05/26/2008 - 07:34
Can you be more explicit about the license please? Is the upgrade to 8.0x free of charge?
Is it valid also for PIX family, like from 6.3(5) to 8.0(3)?
