Citrix ICA tagging over DMVPN
May 22nd, 2008
Has anyone configured NBAR for Citrix ICA priority tagging ?
I have configured NBAR for Citrix ICA priority tagging feature on a 3845 with 12.4(13c) IOS.The citrix server is on a lan g0/0.1 connected to the DMVPN hub router.The citrix admin has configred all the parameters to make ICA priority tagging work on his side. The problem I have is I am not seeing the packets tagged when I access the server over from DMVPN edge router. Whereas the same works when I come from another lan interface g0/1.1 of the DMVPN router. I have used GRE tunneling instead of IPSec DMVPN, but it doesnt work. I am trying to match the packets on the lan interface where the server is connected.
class-map match-any icatag1
match protocol citrix ica-tag "1"
class-map match-any icatag0
match protocol citrix ica-tag "0"
class-map match-any icatag3
match protocol citrix ica-tag "3"
class-map match-any icatag2
match protocol citrix ica-tag "2"
policy-map test
class icatag0
set dscp af33
class icatag1
set dscp af32
class icatag2
set dscp af31
class icatag3
set dscp af23
interface GigabitEthernet0/0
no ip address
ip nbar protocol-discovery
ip route-cache flow
ip policy route-map citrix
duplex auto
speed auto
media-type sfp
no keepalive
service-policy input test
interface GigabitEthernet0/0.1
encapsulation dot1Q 1
ip address 10.244.1.250 255.255.255.0
ip nat inside
ip virtual-reassembly
Rt1#sh route-map citrix
route-map citrix, permit, sequence 10
Match clauses:
ip address (access-lists): any
Set clauses:
ip df 0
Policy routing matches: 541003 packets, 38532833 bytes
Rt1#sh ip access-lists any
Extended IP access list any
10 permit ip any any (543185 matches)
Rt1# sh policy-map int g0/0.1
Service-policy input: test
Class-map: icatag0 (match-any)
0 packets, 0 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: protocol citrix ica-tag "0"
0 packets, 0 bytes
5 minute rate 0 bps
QoS Set: Feature obj ptr is 70A4F794
dscp af33
Packets marked 0
Class-map: icatag1 (match-any)
0 packets, 0 bytes
Match: protocol citrix ica-tag "1"
0 packets, 0 bytes
5 minute rate 0 bps
QoS Set: Feature obj ptr is 70A4F844
dscp af32
Packets marked 0
Class-map: icatag2 (match-any)
0 packets, 0 bytes
Match: protocol citrix ica-tag "2"
0 packets, 0 bytes
5 minute rate 0 bps
QoS Set: Feature obj ptr is 70A4F8F4
dscp af31
Packets marked 0
Class-map: icatag3 (match-any)
0 packets, 0 bytes
Match: protocol citrix ica-tag "3"
0 packets, 0 bytes
5 minute rate 0 bps
QoS Set: Feature obj ptr is 70A4F9A4
dscp af23
Packets marked 0
Class-map: class-default (match-any)
33892 packets, 2757041 bytes
5 minute offered rate 3000 bps, drop rate 0 bps
Match: any
owillins Wed, 05/28/2008 - 12:44
  • Silver, 250 points or more
Use this command show policy-map interface interface-name -- in working interface as well as non working interface verify the both the things.
