Jaime Valencia Thu, 05/22/2008 - 12:26
are you using the EXACT SAME VERSION for the SUB , they need to be an EXACT match
javalenc
if this helps, please rate
gogasca Sun, 05/25/2008 - 11:36
Create the dump file into the USB key
Then upload the file here and also start checking for errors in the install.log
make sure DNS info, CCM pub, Network connectivity is just fine, also that you have add previously the server in CCM Admin.
When you perform a fresh installation of Cisco Unified Communications Manager, you must define any subsequent servers (nodes) in the Cisco Unified Communications Manager Administration Server Configuration window before you can install the Cisco Unified Communications Manager software on each subsequent server.
