AD Integration with CallManager 4.1.3
May 22nd, 2008
  • Bronze, 100 points or more
With synchronization between CallManager 4.1.3 and AD, can CallManager refer to a different field than "Phone" to populate the "Telephone Number" field?
Jaime Valencia Thu, 05/22/2008 - 12:26
  • Cisco Employee,
  • Hall of Fame,
    2011
no you cannot, the plugin does not let you choose which fields you want to use
javalenc
if this helps, please rate
