ASA 5510 cannot connect to the internet
Answered Question
May 22nd, 2008
What's wrong or missing from the configuration below? No internet access. On the ASA, I can ping my T1 router:
T1 router - 69.X.X.193
Outside interface 69.X.X.196
Inside interface 10.10.1.254
asa5510(config)# show run
: Saved
ASA Version 8.0(2)
hostname asa5510
domain-name http://www.test.com
enable password XXXXXXXXXXXXXXXX encrypted
names
dns-guard
interface Ethernet0/0
nameif outside
security-level 0
ip address 69.X.X.196 255.255.255.248
interface Ethernet0/1
nameif inside
security-level 100
ip address 10.10.1.254 255.255.255.0
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
management-only
passwd XXXXXXXXXXXXXXXX encrypted
ftp mode passive
dns server-group DefaultDNS
access-list incoming_traffic extended permit ip any any
pager lines 24
logging asdm informational
mtu outside 1500
mtu inside 1500
mtu management 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-611.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
access-group incoming_traffic in interface outside
route outside 0.0.0.0 0.0.0.0 63.X.X.193 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
aaa authentication http console LOCAL
http server enable
http 192.168.1.0 255.255.255.0 management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
no crypto isakmp nat-traversal
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.1.2-192.168.1.254 management
threat-detection basic-threat
threat-detection statistics access-list
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns migrated_dns_map_1
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
username testuser password XXXXXXXXXXXXXXXX encrypted
prompt hostname context
Cryptochecksum:xxx
: end
asa5510(config)#
Correct Answer by husycisco about 8 years 9 months ago
Hi Andrew,
Nothing is wrong with your ACL or NAT statements.
Your default static route is not within the range of your outside interfacce
Check it again.
Overall Rating: 3.5 (6 ratings)
arturo.guzman Thu, 05/22/2008 - 14:10
nat (inside) 1 0.0.0.0 0.0.0.0 // int this case you have to put your segmente lan maybe like this.
nat (inside) 1 10.10.1.0 255.255.255.0
or may be like this
nat (inside) 1 10.0.0.0 255.0.0.0
In other hand you have to make an acl for the inside interface maybe like this.
access-list inside_in extended permit ip 10.10.1.0 255.255.255.0 any
and apply it to the interface.
access-group inside_in in interface inside
don't forget qualify me
Correct Answer
husycisco Thu, 05/22/2008 - 16:13
Hi Andrew,
Check it again.
vitripat Thu, 05/22/2008 - 16:41
This is not a issue with either nat/global configuration or subnet mask. Outside interface and gateway IP are in the same subnet.
I think this is an issue with the upstream device. To verify, try this-
inspect icmp
Now check if from hosts on the inside interface, are you able to ping 63.X.X.193 and 4.2.2.2?
If you can ping 63.X.X.193 but not 4.2.2.2, traffic is passing through ASA, however not through the upstream device (router). Thats where you need to look in.
Vibhor.
husycisco Thu, 05/22/2008 - 17:00
Hi Vibhor,
"Outside interface and gateway IP are in the same subnet"
Following is the ip address statement for outside interface
and following is the default route
How can 63.x.x.193 be within same subnet of 69.x.x.192/29 ?
According to the config of T1 router, the default route for ASA must either be the T1 router itself (69.x.x.193), or the default gateway assigned to T1 router by ISP within 69.x.x.192/29
vitripat Fri, 05/23/2008 - 09:38
ahh .. i missed that .. :-) Thanks for pointing it out. :-)
