05-22-2008 01:50 PM
I just read about the Cisco 3002 Hardware Client and was excited as it met my needs for remote access Lan to Lan connectivity. Then I found out it is discontinued. Is there a replacement product.
05-23-2008 07:44 AM
Any of the 800 series routers will do this function just fine. Also, the pix 501 or the asa 5505 will as well. Just configure them for easyvpn.
05-23-2008 09:20 AM
asa 5505 is a good replacement. pix 501 is nearing death.
05-27-2008 03:27 PM
Thanks!
05-23-2008 02:25 PM
You can get any 800 Cisco router box and configure EZVPN in it. For you LAN-to-LAN needs you can configure an EZVPN feature that is called NEM - Network extension mode, along with autoconnect
05-23-2008 04:08 PM
same thing on the 5505
