memory free low-watermark - threshold values?
I have a 3750. What values do I use for the memory free low-watermark thresholds? Here are the outputs from the show memory:
sand5# sh mem
cisco WS-C3750G-24T (PowerPC405) processor (revision E0) with 118784K/12280K bytes of memory.
Here are the values from a 6513:
SITSF-Central-Cat#sh mem
cisco WS-C6513 (R7000) processor (revision 1.0) with 458720K/65536K bytes of memory
Overall Rating: 5 (1 ratings)
michael.leblanc Thu, 05/29/2008 - 17:52
The 3750 shows the "lowest" amount of Processor memory available (presumably since last boot) as 43,916,928 bytes.
Perhaps if you monitor "free" and "lowest" Processor/IO memory over time, you can identify baseline values, then decide how much of a deviation would warrant notification.
The values will change as new features are brought online, and loads increase. So it will warrant periodic re-assessment.
Unfortunately, I think it is up to you to decide how low you wish to allow "free" memory to dip below your baseline before generating a notification.
I set my thresholds a couple MB lower than my baseline. If a notification occurs, I determine how low it went, and try to correlate it to a reason.
I'm doing what makes sense to me without guidance from anyone who might know better.
I'm not sure that there is a "right" answer.
That's all I can offer.
www reference:
Guessing is the only way.
With 78MB of processor memory:
Router(config)# memory free low-watermark processor 10000
This sets the warning threshold to 10MB. i.e. 10%, sort of.
With 12MB of io memory:
Router(config)# memory free low-watermark io 1000
Sets the warning threshold for io to 1000. i.e. 10%
Out of 100MB total, keep a meg reserved for critical operations:
Router# memory reserved critical 1000
i.e. 1% @ 1MB.
memory reserve critical 1000
memory free low-watermark IO 1000
