Help configuring a Cisco CIGESM module in an IBM Blade Center.
Answered Question
May 22nd, 2008
I have an IBM BladeCenter with a Cisco CIGESM switch module. This module runs IOS, which I'll admit I don't know much about.
I've cabled all four external ports (g17-g20) to four ports on a Linksys SRW2048. On the Linksys, I've grouped those 4 ports in a Link Aggregation Group, and enabled LACP.
I can't find a way to set the equivalent configuration on the CIGESM modules Web Interface. I also tried the command line, but I haven't stumbled on the right commands yet.
Can anyone give me some hints or tips?
-Kyle
Correct Answer by glen.grant about 9 years 2 months ago
You put those commands on the ports themselves , the best way to do it is to use the interface range command and put it on all the ports you want in the channel group at once. Once you add those commands it automatically creates the interface portchannel . All IOS switches create port channels the same way , if the 6513 is a hybrid box then thats a different story. "channel-group x mode active" actually goes on the interfaces and that creates the port channel .
Overall Rating: 4.3 (4 ratings)
glen.grant Thu, 05/22/2008 - 17:17
  • Purple, 4500 points or more
I have never used the GUI to do these or any other cisco switch but I know the switches support both LACP and PAGP for etherchannel aggregation. If doing command line just add the the following " channel-group 1 mode active " .
kylejmcdonald Thu, 05/22/2008 - 20:28
Thanks, but I'm still missing something.
That command looks like it will enable the group once it is created, but I'm still not sure how I define the group to contain ports g17, g18, g19, and g20?
Where do I pick between LACP and PAGP?
Thanks Again,
-Kyle
glen.grant Fri, 05/23/2008 - 03:31
If you are talking about the GUI afraid I can't help there . CLI wise when you use the command channel-group X mode active" that makes it LACP , if pagp it would be channel-group X mode desirable silent or non-silent .
kylejmcdonald Fri, 05/23/2008 - 05:20
Ok. I'll read that, thanks!
Glenn, I'm talking about the Command Line, the Web GUI doesn't have any way to do this. Though I did finally stumble on a way to do this in CNA - It wasn't obvious though, I had to click a link in the help window to get the window up, I couldn't find a menu or button for it anywhere.
I guess what I couldn't understand was why there wasn't any mention of ports I wanted in the group. If I'm enabling channel group 1, how does the switch know that group 1 is made up of 17, 18, 19, and 20?
Thanks Amit, Thanks Glenn, this info has been helpful.
-Kyle
kylejmcdonald Fri, 05/23/2008 - 07:23
Another question if I can?
I want to use another LAG for the uplink from the Linksys SRW2048 to the Lab Cat6513.
Are the commands to setup the LAG going to be pretty much the same on the 6513?
The Blade Switch module has a limit of 6 Channels, What is the limit on a big switch like the 6513? Is it for the Chassis? or the switch card in the chassis?
Thanks again!
-Kyle
Correct Answer
glen.grant Fri, 05/23/2008 - 07:52
