CUCM 5.0(2)
May 22nd, 2008
Hi all,
I have call manager 5.0(2) in a LAB enviroment and was able to login to the admin page. But for some reason I am no longer able to login to the admin page when I try to login, I keep getting prompted for Username and password and the address bar changes to https://xxxx/ccmadmin/WEB-INF/pages/j_security_check.
However I can login to IPTPLATFORM page and disaster recovery System.
Any suggestions?
bwilmoth Wed, 05/28/2008 - 12:46
Restart the Database Layer (DBL), the Real-time Information Server (RIS) services and then the IIS service. Then, before you attempt the next procedure, and if you know the MLA password, try to login to the Cisco CallManager Administrator page.
If you cannot login with Cisco CallManager Administration or you forget the password for Cisco CallManager Administrator when MLA is enabled, then you need to login as Administrator. This is possible only if MLA is disabled. MLA needs to be disabled from the Cisco CallManager Administration page. But since the login for the Administration page fails, an alternate method is to use the SQL Enterprise Manager to disable MLA.
You can refer this document for more information.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00800e1691.shtml
