CSM Backup serverfarm prob.
May 22nd, 2008
I have two 6509 and two CSM module.
serverbank-I is conected with the 6509-1 and second serverbank-II is connected to 6509-2, and 6509-1 and 6509-2 are connected to each other via CWDM link,
I can access all the real servers from both switches,
My problem is,
If i configured serverfarm-I with Backup srverfarm-II on both the csm module it will work ?
ebreniz Wed, 05/28/2008 - 12:40
The CSS only allow 1 backup server. When a client is connected to a server, it stays connected to that server even if a new server goes up. Only new connections from the client would be sent to a different server.
We are building a transparent caching scenario with CSM running 4.2(3) on a cat6509 with sup2msfc2pfc2 running 12.2.(18)SXD7. The CEs are 7325A and are running ACNS 5.2.7b7.To test the backup server farm feature we configured a server farm called CE-FARM:
server farm CE-FARM
no nat server
no nat client
predictor hash url
failaction reassign
real 192.168.6.1
inservice
probe ICMP-PROBE
Cat6509#show mod csm 8 serverfarms name ce-farm detail
CE-FARM, type = SLB, predictor = URL Hash
nat = None
virtuals inservice = 2, reals = 1, bind id = 0, fail action = reassign
inband health config:
retcode map =
Probes:
ICMP-PROBE, type = icmp
Real servers:
192.168.6.1, weight = 8, OPERATIONAL, conns = 17
Total connections = 17
This server farm (CE-FARM) is our main server farm.
The backup server farm is called dummy and for testing the backup feature its configuration is:
serverfarm DUMMY
no nat server
no nat client
predictor hash url
failaction reassign
real 192.168.6.5
no inservice
real 192.168.6.6
no inservice
real 192.168.6.4
no inservice
real 192.168.6.3
no inservice
real 192.168.6.2
no inservice
probe ICMP-PROBE
Cat6509#show mod csm 8 serverfarms name dummy detail
DUMMY, type = SLB, predictor = URL Hash
nat = None
virtuals inservice = 1, reals = 5, bind id = 0, fail action = reassign
retcode map =
Probes:
Real servers:
192.168.6.5, weight = 8, OUTOFSERVICE, conns = 0
192.168.6.6, weight = 8, OUTOFSERVICE, conns = 0
192.168.6.4, weight = 8, OUTOFSERVICE, conns = 0
192.168.6.3, weight = 8, OUTOFSERVICE, conns = 0
192.168.6.2, weight = 8, OUTOFSERVICE, conns = 0
Total connections = 0
Then we associated these two server farms in a vserver called DUMMY for which server farm CE-FARM is the "main" server farm and server farm DUMMY is the backup.
The vserver DUMMY is associated with the overall configuration of the scenario but for now I ask you to consider its existence only for propose of testing the backup server farm feature.
vserver DUMMY configuration is:
vserver DUMMY
virtual 192.168.9.250 any
advertise active
persistent rebalance
slb-policy DUMMY
inservice
where slb-policy DUMMY has the following configuration:
policy DUMMY
serverfarm CE-FARM backup DUMMY threshold inservice 4 outservice 3
From the above configuration we were expecting the following:
-server farm dummy would be used in case less then 3 reals were available on the server farm CE-FARM.
-server farm CE-FARM would be RE-used in case at least 4 real were available.
Cat6509#show mod csm 8 vservers name dummy detail
DUMMY, type = SLB, state = OPERATIONAL, v_index = 12
virtual = 192.168.9.250/32:0 bidir, any, service = NONE, advertise = TRUE
idle = 3600, replicate csrp = none, vlan = ALL, pending = 30, layer 7
max parse len = 2000, persist rebalance = TRUE
ssl sticky offset = 0, length = 32
conns = 0, total conns = 0
Policy Tot matches Client pkts Server pkts
DUMMY 0 0 0
(default) 0 0 0
Cat6509#show mod csm 8 policy name DUMMY
policy: DUMMY
type: SLB
serverfarm: CE-FARM
backup serverfarm: DUMMY (no sticky)
With this scenario we were expecting that with all reals in server farm DUMMY out of service and only one real inservice in server farm CE-FARM the vserver DUMMY would be out of service.
This configuration is strange ... in fact we are testing a way of influencing the MSFC routing table (please notice advertise active command on vserver DUMMY config) when a certain number of CEs is out of service.
Syed Iftekhar Ahmed Thu, 05/29/2008 - 12:00
Yes. It will.
Make sure that the client/server vlans exist on both chasis and are trunked between two chassis.
Syed
