no busy tone and no Announcement Messages from pstn/gsm gateway
May 22nd, 2008
make an outbond call from sccp ip phone to pstn/gsm phone using SIP gateway (cisco 2800) no busy tone and Announcement Messages received, Continuously bell are ringing please help
rhobab Wed, 11/19/2008 - 05:05
Hi there
I have the same issue and the cimmand you suggest does not solve the problem.
Victor
Yorick Petey Sun, 01/11/2009 - 08:49
Hi Victor,
I have the same issue. Even with this commad, the call is still ringing and I don't receive the announcement from the operator in case of wrong number.
Did you solve this issue?
Thank you.
Yorick
rhobab Mon, 01/12/2009 - 04:41
Try the command "voice call convert-discpi-to-prog" in global configuration as stated by an earlier reply. At first I was not putting the command right but now it is ok.
Victor
Yorick Petey Mon, 01/12/2009 - 04:50
Hi Victor,
I tried this command but I cannot see any difference with or without it.
Which IOS version do you use? I tried with 12.4(9)T7 and 12.4(15)T8.
Thank you.
Yorick Petey
Yorick Petey Mon, 01/12/2009 - 10:34
Victor,
Can you send me your running-config?
It's strange, I am using 12.4(15)T8 which is only a Maintenance release, so it should work.
What is your CUCM version? I am using the new 6.1.3.
Thank you very much.
Yorick
Yorick Petey Mon, 01/12/2009 - 10:56
Hi java,
This command is already here. Please find attached my current configuration.
(removed some infos for privacy)
Yorick
